I said flow... not pressure.
Big difference between the two.
Flow and pressure are certainly different things. But I’d like to touch on this point cause it caught my eye.
If the line leading to the injection pump has a given pressure, say for the purpose of discussion 5 psi, and the tractor runs normally under load, and then for unknown reasons, the engine loses power— while the fuel pressure in the line feeding the injector pump remains constant at 5 psi—wouldn’t this indicate that fuel delivery was adequate, since if fuel delivery was an issue, the pressure supplied at (or close to)the pump should drop?
Could such a scenario point to an injector pump issue?
Fuel pressure can be monitored relatively easy while the tractor is working. Seems like fuel flow would be a lot more difficult to measure in that situation.
I do understand that if one measures fuel pressure when the engine is not running, and there is no flow, that measurement does not mean a whole lot. I suppose one could check when the tractor was not running what the fuel flow is (if there is an electric fuel pump) by putting a valve on the end of the line and measuring flow versus pressure as the valve is gradually opened.
In the case of the OP‘s tractor, what’s the best way for him to measure fuel flow meaningfully?
