C Cpowers87 New member Equipment 2022 b2601 May 8, 2022 4 0 1 Michigan May 8, 2022 #1 Any help would be great. Lost this pin while mowing today. It is right behind left rear tire. Connects MMM to lift and raise. Looking for size or link to specifics on this pin or anything else I might have lost there. Thanks!
D dirtydeed Well-known member Lifetime Member Equipment B2650 BH77, U27-4R2, BX23TLBM, box blade, rear blade, flail mower, Stump Grinder Dec 8, 2017 2,901 3,257 113 Wind Gap, PA May 8, 2022 #2 Check to see if pin No. 80 or no. 100 fits there. I found the lift arm but can't locate the figure number J310XX. Here's a link to the figure in the picture. https://kpad.kubota.com/books/2760/figs/194755?illust_index=-1 Maybe its located in a figure for your MMM. What model is the mower? Edit: Parts link for 54" deck. https://kpad.kubota.com/books/558/figs/21876?illust_index=0 Part Link for 60" deck. https://kpad.kubota.com/books/559/figs/21891 54" 60" Last edited: May 8, 2022
C Cpowers87 New member Equipment 2022 b2601 May 8, 2022 4 0 1 Michigan May 9, 2022 #3 I have the 60” deck. Rck60-32.
D dirtydeed Well-known member Lifetime Member Equipment B2650 BH77, U27-4R2, BX23TLBM, box blade, rear blade, flail mower, Stump Grinder Dec 8, 2017 2,901 3,257 113 Wind Gap, PA May 9, 2022 #4 did you not see the parts diagram above? It looks like both decks use the same pin. It's part no. 50 above. P/N 05122-51240
B737 Well-known member Lifetime Member Equipment LX3310 Jun 9, 2019 2,024 2,197 113 New Jersey May 9, 2022 #5 Reactions: 1 users
C Cpowers87 New member Equipment 2022 b2601 May 8, 2022 4 0 1 Michigan May 9, 2022 #6 dirtydeed said: did you not see the parts diagram above? It looks like both decks use the same pin. It's part no. 50 above. P/N 05122-51240 Click to expand... Sorry. New to this forum and tractor thing! Thank you for your help!!!!
