Log Tongs for my Boom Pole
Trimley
BX23SLSB-R-1 plus additions
Jul 25, 2023
1,181
872
PNW-WA
Found a nice vintage Tong Set on FleaBay for $31.23/shipped.
For use with my Boom Pole.
Edited to add> This will get the below type of cleaning method.
Reactions: 8 users
pigdoc
G1800S L2500
Aug 19, 2022
363
291
SE Pennsylvania
Very nice!
I'm envious!
I was JUST thinking today that I really need one of these.
I have measured and marked about 50 mature Black Birch trees on my property that I want to harvest this winter. I'm going to use the L2500 to skid them out to the road, and probably load them too (need some forks). I have about 9000BF total (1/4" rule). The biggest tree is almost 500BF (1/4" rule) and will weigh about 1.5 tons.
My dream is to tear out the wall-to-wall carpeting, and replace with Black Birch flooring. But, rather than worry about the drying and machining, I'm just going to sell the saw logs, and then turn around and buy ready-to-install flooring. I need about 2000SF of flooring. There's a place in Connecticut that has a nice line...
-Paul
Trimley
Jul 25, 2023
1,181
872
PNW-WA
Very nice!
I'm envious!
-Paul
I was a flooring contractor for 37 years. Anymore, I claim to know nothing but how to walk on it!
jyoutz
Jan 14, 2019
3,472
2,556
Edgewood, New Mexico
Very nice!
I'm envious!
-Paul
Log tongs are nice for sorting logs at a milling location, but cable chokers are better for skidding logs. Pull from your drawbar, not 3ph.
5,436
I have a pair pretty similar to that. Been using them off and on about 50 years. My father and unknown ancestors before him used them as well. They’re very handy in some situations. Can significantly increase efficiency as well. If you treat them like they’ll hold a log as securely as a hydraulic grapple/thumb or a choker chain… well that’s just not very bright. But the whole subject of tractors and similar equipment is that way. Use it right: good 👍🙂. Use it wrong: bad 👎☹.
Nice find.
Trimley
Jul 25, 2023
1,181
872
PNW-WA
Nice find. View attachment 116425
How true those words are. Relevant to everything, almost literally.
My being born and raised in times when the timber industry was boonin in my parts, I grew up around everything "timber", I may have been around the block a time or two 😉
g_man
Feb 3, 2023
323
1,464
NE Vermont
That's a very nice set of old tongs. They look small to me for something coming out of the PNW. I picture everything out there as big :) But they should be fine on your boom pole. Keep them them sharp.
gg
g_man
Feb 3, 2023
323
1,464
NE Vermont
I used tongs before I got a winch.
gg
Trimley
Jul 25, 2023
1,181
872
PNW-WA
My tongs will have minimal use, if at all. As a tool for someone living in the sticks, they're good to have around.
KKBL
L2501 HST QA 525 loader, 42" forks, brush hog, grader/box/back blades
Jan 5, 2022
125
137
Girard, PA
We have used tongs with a boom pole for years - no problems. Make sure the logs you drag will not hit your PTO shaft.
In Utopia
L175 FEL
Apr 21, 2013
648
173
Utopia,Tx/Pasadena,TX
Used mine once trying to move power poles. Turned out to be a pain, went back to choking with cable on the winch mounted on my boom pole.
Sold the tongs.
g_man
Feb 3, 2023
323
1,464
NE Vermont
I like mine for some things. I made an over the center latch to hold them open. Then I can drop them on a log and go w/o getting out of the seat. I made a little video the very first time I tried it out to see if it would even work.
gg
Hkb82
Nov 17, 2021
418
330
Ontario Canada
I also made a set of scissors tongs thinking it would be way easier then choking all the time. They worked good but I still prefer to use logging chain and choker to skid logs from the bush. Choker never comes off but the tongs do from time to time.
Trimley
Jul 25, 2023
1,181
872
PNW-WA
Let's put it this way, Tongs are something I did not have and wanted. I have chains, cables, snatchblocks, winch, chokers and on an on. I use what works best. I work smarter> not harder.
Hkb82
Nov 17, 2021
418
330
Ontario Canada
I hear ya on that. That’s why I built mine. You got a sweet deal on a set of tongs and sure couldn’t go wrong for 30 bucks. No brainer if you ask me.
KKBL
Jan 5, 2022
125
137
Girard, PA
With some practice, you often don't have to get off tractor to grab a log and go. Saves time when moving lots of wood.
Trimley
Jul 25, 2023
1,181
872
PNW-WA
Right. Once they arrive..then cleaned up, I'll play with making (adding) a scissor cross-bar that holds them open until dropped on the log. Some chain on each side also...for flexible draft links....to keep them aligned.
