Log splitter control valve lever sticking
imarobot
5740HSTC-3, FDR2584 Finish Mower, BH92 Backhoe, L2195A Snowblower, LA854 FEL, +
Apr 18, 2025
425
316
NH
Has worked fine for years with no sticking ever. Used the splitter yesterday and lever was sticking right from the start and now sticks all the time. I cleaned up the outside of the valve to make sure there was no debris causing this with no improvement. So, I'm assuming there is something in the valve causing it to stick. The controller valve has a cap on the back which I am assuming there is something in there that may be the issue. This is on a Ariens 22-ton splitter.
Lencho
B7100hst
Jan 21, 2017
453
122
NM
Hi Robot,
I have a different brand splitter but they may be similar. The end cap (away from the control leaver) just unscrews to reveal a threaded bolt and lock nut system. You can adjust it a bit when needed. Mine has “auto return” to pull the wedge back into the cylinder and it is a bit touchy on adjustment. IMG_0047.jpeg
imarobot
Apr 18, 2025
425
316
NH
The end cap on mine is very similar to what you have. May be obvious when I see it, but do you adjust it by tightening or loosening the bolt?
I'm not sure if it's auto return, but the valve does have a "locked" position when the lever is pulled back to retract the cylinder. Under normal operation the valve would kick out to the neutral position. Now it either gets stuck there or eventually kicks out so hard the cylinder moves in the extend direction.
Lencho
B7100hst
Jan 21, 2017
453
122
NM
Yep, just loosen the nut and then the bolt can be turned. It puts pressure on the valve I think. Try a small adjustment and you should learn which way improves operation. Trust yourself.
imarobot
Apr 18, 2025
425
316
NH
Well, my valve is different, it doesn't have a nut and bolt replacement. Picture showing the end didn't come out that well, I'll get a better one.
7,344
What is the Brand snd model number on the valve? If you cant fix it replacement log splitter valves are not expensive.
imarobot
Apr 18, 2025
425
316
NH
Sorry Dan, just seeing this now, I don't know why I wasn't flagged about your message.
After further investigation, I found that it is an Energy Mfg valve and according to them is a spec'ed valve by Ariens. I ordered one and hoping it is the right one 🤞
And yes, replacement parts were almost the cost of the valve.
