Ok folks need a little help? every-time i go to reverse and touch the shifter to go to any forward gear the transmission locks up. I pull the top off and there is three long shafts the right and left shafts have rods going to shifter forks. The middle shaft has a spot for the shifter ball when in neutral. What i need to know and can not tell in my book should that center shaft shifter mec move or should there be a pin or something to hold it still? mine the mec moves all over the shaft. It has a hole in it but i do not know what would go in it to hold it still. Hope you understand what im asking hard to ex-plane
