Loader weight
zoomy
l5740,6' Brush mower, Bobcat 873,Marshal tree saw, 48" Pallet Forks, Bobcat T770
Feb 22, 2014
51
Mundelien, IL
The specs for my 2008 L5740 say that the cab model weighs 4223 pounds but does not specify if that weight includes the LA854 loader and bucket. If it does not, does anyone know what the loader and 72" bucket weigh? I want to haul the tractor on my brother in laws trailer and it has a 6600 pound capacity. The rear tires on my tractor are loaded with 1100 pounds of beet juice and I will be taking a 750 pound box blade with.
olthumpa
L275
May 25, 2011
1,501
Maine
L5740 w/cab 4223
FEL 1300 lbs.
loaded tires 1100
box blade 750
_____
7523 lbs approx
Now add fuel etc.
:eek::eek::eek::eek::eek::eek::eek::eek:
zoomy
Feb 22, 2014
51
Mundelien, IL
L5740 w/cab 4223
FEL 1300 lbs.
loaded tires 1100
box blade 750
_____
7523 lbs approx
Now add fuel etc.
I think I'll have to talk my brother in law into buying a bigger trailer.:rolleyes:: Thanks.
Bulldog
M 9000 DTC, L 3000 DT
Mar 30, 2010
5,434
77
Rocky Face, Georgia
Keep in mind (in most cases) the trailers rating doesn't include the weight of the trailer it'self.
Another words, a trailer with 2 3500# axles (7K rating) that weighs about 2000 lbs can really only haul 5K if you go by the rating. So assume the heavier trailer weight is 2500 - 3000 lbs and the tractor is around 7500 lbs. You need a trailer rated for 10K - 11K to be safely within the load limits.
zoomy
Feb 22, 2014
51
Mundelien, IL
Thanks for the info about weight ratings. A friend is borrowing me his goose neck equipment trailer that he hauls his 9500 pound excavator with. I have a GMC 3/4 ton pickup with a Duramax diesel to pull it. Should work out fine.
