Loader Mounted 2782B Snowblower
Kubotank
B2650HSDC
Oct 17, 2019
New Brunswick
Does the frame stay on all the time? Did you use existing hole in the frame or did you have to drill new holes.
This is exactly the type of setup I am looking for. Being able to leave the loader frame on and use the front mount snow blower.
If you don't need your mid PTO for a mower or something else the subframe can stay on all the time.
I remove it during summer because I have a mid mount mower. It's really easy to remove and install and even if I wouldn't use the mid PTO, I would still remove it in summer because it lower the clearance under the front axle.
No i didn't drill any holes, the subframe is using the existing holes in the frame.
Jsjac
B2650
Feb 13, 2022
244
402
This is going to be one of the projects that I work on over the summer.
I have a land pride snow blower on the rear now.
I am going to try to make that work.
Kubotank
B2650HSDC
Oct 17, 2019
New Brunswick
The 3pt rear blower may not work in front, you will need a reduction box because the mid PTO run at 2500rpm compare to 540rpm in the back.
Jsjac
B2650
Feb 13, 2022
244
402
I did not even think of that. I guess I will have to buy one of the blowers.
Maybe I can buy just the blower and not the whole kit?
Orange1forme
Dec 1, 2018
401
66
Wa
Looks like this is the OP.
At first I thought this was a strange idea, but with an explanation it seems like a good idea when done correctly.
Jsjac
B2650
Feb 13, 2022
244
402
I looked around on the interwebs and found a couple.
I will wait until winter is over to start looking.
If I have to buy new I will. Prefer not too,but ...
