Loader Controls
Dae06
2019 Kubota B2650 Cab.
May 10, 2018
173
11
Minnesota
I went to the dealer to buy the Kubota B2650 with cab Saturday. I went to drive it one last time and the loader controls did not work correctly. The right and left (curl/dump) function would dump, but we could not get it to curl. The salesman tried with no luck as well. He said he would get the service guy to look at it, but he was busy so we left.
I got a text from him a little later on saying that there was nothing wrong with it, we were just pushing it through the "float detent" to the right.
My issues with that answer:
1). I believe there are 2 detents to the right for 2 different dump speeds no "float detent".
2). That doesn't explain why we couldn't curl it (bringing it to the left).
Lift arm function worked fine and all hydraulic connections matched up color wise.
I'm not sure what to think. Any ideas?
boz1989
B2910 fel 60 mmm, Land Pride rb1572
Jun 10, 2015
269
Portland, MI
Sometimes the quick couplers don't latch properly and have to be reconnected. I've had this happen to me a few times.
Sent from my LGMP260 using Tapatalk
sheepfarmer
Nov 14, 2014
4,438
677
MidMichigan
There is some confusion here, not sure what you or they are thinking. There are two detents, but one is all the way forward, and is for float when the bucket is on the ground. The other is all the way to the right, and I use for the hydraulic control of the snowblower chute. Otherwise right ( before the detent stop) is dump, and curl is left. If you get it stuck in the right detent position it wouldn't be able to curl until you pulled it out..???
6,036
The detent all the way to the right basically opens the port to rapidly dump. It allows the bucket (if that's what's attached to the loader) to gravity dump instead of a hydraulically powered dump.
The same position is also used for other front mounted implements.
groomerbuck
137
Palmerton, Pennsylvania,
My bet it the hydraulic couplers werent coupled properly. The same thing happened to my b2650 when i went to pick it up. The salesman was “showing” me how to hook them up but he apparently didn’t know too well himself as i had to steer him in the right direction.
Dae06
May 10, 2018
173
11
Minnesota
Turns out two hydraulic hoses were switched around incorrectly. The colored plugs/caps were put on the hoses incorrectly.
TRA
B2601, LA434, BH70, LP BB1260
Dec 17, 2017
88
Rock Hill
Same happened to me once, first time I removed my backhoe.
