Loader Bucket wont hold position
B1550
Kubota B1550, tiller, rock rake
Apr 20, 2015
Lake Stevens
Hi everyone
I have a B1550, everything work great on it but the loader bucket won’t stay in position once I let go of the control handle. Even when the bucket is empty the bucket will start to fade downward and with a load in the bucket it fades much faster.
Any help would be appreciated.
10,197
First swap the up down lines for the roll lines, if the fade moves to the lift then it's a bad Spool valve.
If it doesn't move you will need to rebuild the cylinders. ;)
B1550
Apr 20, 2015
Lake Stevens
Thanks for your quick response.
I did the swap and the fade stayed the same.
Thanks for the information.
Hotmetal
1995 B7100HSD, B1630C loader, bush hog.
Jan 13, 2015
22
Lyme, CT
www.perennialdesigns.net
FYI. I recently had the same problem on a B7100. Wolfman's test indicated the bucket cylinders were the problem as well. I rebuilt my cylinders and it cured the problem. I am attaching a pic of the offending seals. The top center is a new T seal. The bottom two are left and right cylinder seals I removed. I couldn't believe the right side one.
Tooljunkie
May 13, 2014
4,150
34
Best advice i can offer is keep everything clean. The cleaner the better. Blast/flush the new hydraulic hoses too. Dont trust that because they are new that they are clean.
Overhauled a set of cylinders a while back, replaced hoses also. A piece of something got in and scored a cylinder. All that work and it still leaked down.
