lift arms
Vern
Finishing mower
Jul 7, 2018
LaFayette ,Al
Lift arms on Kubota BB200 not working. Anyone have any ideas. Just bought tractor and have no experience with Kubota tractors. The lift arms will not move up when lever is moved to the lift position. Also on the side cowling from the factory are the info BB200
bucktail
Jun 13, 2016
1,276
198
MN
We need more details. What isn't it doing that it's should or what is it doing that it shouldn't?
9,888
Most of all we need a real model # as Kubota never made a BB200. ;)
rbargeron
Jul 6, 2015
1,183
260
western ma
Yes, listen to Shirley :D actual model number tells everything. B8200 maybe?
MilkyWay
181
11
Dahlonega, GA
Is there a valve on there somewhere, possibly on the loader that isolates the loader from the 3 point. That***8217;s how my L245 was.
I have a L5450 and no experience whatsoever with any other models, but on the 5450 if the rear hydraulics are engaged, such as when I am using my wood splitter, the lift arm is disabled. I have never tried engaging the rear hydraulics control without first attaching the wood spitter, so I don't know if the lift arm would be disabled, even if the hydraulics are not circulating. Which would be the case if the control calls for rear hydraulics but no implement attached; I think. :confused: Since you have just started learning your machine, do you know if it is equipped with rear hydraulics? If so, that is the first thing to check. I imagine it is something simple that you don't know to check until you are more familiar with it.
tdspurrier
25
cincinnati
I have a b8200 with the same issue. I cleaned the proportion valve and hyd oil with no improvements. is there away to test the hyd pump itself. The PTO works but the three point arm will not lift
Also how I tell what year it is
Tom
