lift arm
ynnadresoob
b7200
May 14, 2014
HUGHES ArKANSAS
I have a kabota b7200 one of the arms that lift the three point hitch stripped out does anyone have any ideas I have tried to find another arm with no luck ddoes anyone know if the splines are the same on a different model or know of anyone with a used arm
gpreuss
Oct 9, 2011
1,166
Spokane, WA
This should be quick work for your dealer's Parts Dept. Are the shaft splines still OK?
ynnadresoob
b7200
May 14, 2014
HUGHES ArKANSAS
I have tried a dealer they said it was no longer available I need to find something that will work splines are still good on the shaft so I would rather not try welding it I tried to drill a hole in the shaft so I could use a bolt but the shaft is harder than the drill bit anyone have any other ideas
cerlawson
rotiller, box scraper,etc.
Feb 24, 2011
1,067
PORTAGE, WI
Consider a machine shop for building up the stripped opening, followed by machining the splines. Not out of the question for a good mechanic machinist.
kubotasam
Apr 26, 2010
1,208
131
Alfred Maine
I just went to the Kubota parts site and got the part #. Then went to messicks site and entered it. The original part is discontinued but has been replaced by another # which has been replaced by another #. It looks like a lift arm kit is available. I did this in quite a hurry so I could be wrong. Call Messicks they are great a helping and fast with shipping.
8,279
The price on that kit is really good!
Get a pair of seals for it too. ;)
