Leaking Front-End Loader Control
chruzz
L1501
Sep 5, 2012
Australia
Hi,
I have a front-end loader that is leaking oil from a side bolt on the control assembly.
A picture if where it's leaking can be found here
http://goo.gl/AJ97Kp
How should I go about fixing it, I have no knowledge of hydraulics. I don't know if I should un-do the leaking bolt and replace the seal under it (assuming it has one) and if I should do this do I then need to bleed the system or top it up.
3,093
Link does not work, and more info would be helpful…..
8,741
Second the need more info, and the link doesn't work. ;)
chruzz
L1501
Sep 5, 2012
Australia
Hi Guys, sorry I accidentally deleted it. I have attached it here
My Tractor is a Kubota L1501. I guess I just wanted to be sure before I pull it apart. Should I drain and replace the oil? Will it need bleeding?
chruzz
L1501
Sep 5, 2012
Australia
Hi,
Pic in the post above this one
8,741
Sorry must have missed your other post. :eek:
What's leaking is not a bolt but a plug, probably loose or a bad O-ring, should be a simple fix.
You might be able to just pull the plug with the valve still mounted, just put a bucket under it before you pull it out as a little fluid will leak out.
No need to drain anything and it will bleed/purge any air out all on it's own when you start it back up.
