landpride RTA1250 or RGR 1250 with bx2680
silvertaco81
bx2680
Oct 1, 2018
WAUKESHA
I have a bx2680, i am going to do some tilling with it, i am not sure the pros and the cons of each of these pieces, can you give your advice? i kinda like the 6 tine tiller, heard is makes soil light and fluffy. let me know thanks
mickeyd
Mar 21, 2014
1,192
17
38
Guin, AL
Welcome to the OTT forum. You have joined a great site. Enjoy.
I have the RTA1258 model and really like it. It will till faster and deeper.
It gives great light soil to plant with.
I had a much cheaper tiller before that even if you went over it 6 times it would not be that light.
Dennis42
L3301 HST w/ LA525 FEL, BH77 w/ thumb, QH15, LP-BB2560, LP-RCR1860
Jul 31, 2017
Ashville, AL
mickeyd,
Living that close to the factory, why did you choose the LP-RTA1258 over the King Kutter model? I am in the market for a tiller and got a price from them for the RTG-60-YK that my local Kubota dealer could not get close to.
mickeyd
Mar 21, 2014
1,192
17
38
Guin, AL
The reason I took the LP at that time, was because it was part of my tractor purchase so I got 0% on everything.
Are you planning to come over here to pick it up?
Dennis42
Jul 31, 2017
Ashville, AL
If I go that way. I talked with the factory and was informed that my location was considered local and I could purchase directly from there. I just have to decide which way I want to go, forward or reverse, LP or KK.
War Eagle
2012 B3000HSDC and Allis Chalmer 5020
Jan 15, 2017
101
20
Nampa, Idaho
I chose a KK II which is reverse rotation with 6 tines per flange. The LP only had 4 tines per flange. The KK had one more flange to the rotating shaft than the comparable LP did.
Haven't used an LP to compare the results that the KK II gives me but the KK II does a really fabulous job.
mickeyd
Mar 21, 2014
1,192
17
38
Guin, AL
The big decision between forward or reverse is normally based on your soil.
If your land has big rocks or a lot of tree roots then most go with a forward tiller so that it will walk over them and not hang up the tractor.
If your land in sandy with nothing much in it , the reverse tiller is considered a little better. Also, the reverse tiller will use more HP even if you don't try to go deeper or faster on each pass.
