FiveOfastback
B2650 cab LPrcr1860 LPpallet forks 4240 60" material with tooth bar
Trying to get my QH15 to hook up to AT 2672 It is no problem on just lower arms and top link ie without the QH15.
I have tried everything I can think of. Moving lower links in and out on AT mower Top Hook is my issue I guess.
The mower came with a floting link though not the same as link I have on new brush mower LP RCR1860.
It uses cast link in between.
Both are QH compatible though the AT finish is much older model.
Issue is as I raise the 3 pt and it starts to lift the deck the top hook doesn't stay engaged with the link. Ive tried with and without link. numerous top link adjust in and out.
Should I order a cast link piece that is same as the brush cutter?
Otherwise I load everything up on trailer and haul to dealer.
I have bushings bolts you name I have it for this but to me the top hook needs to be lower to stay engaged. Ive tried lowest points and couple others on top hook of QH.
Am I missing something obvious?
HELP!
HELP!
