Land Pro 5 foot brush hog separation
fma1015
12
Raymond, WA
I did not know the clutch of the mower was bolted on so the drive shaft separated for the mower. I found the bolt, but the clutch end of the drive shaft did not want to slide back on the mower end.
Do I?
Detach the clutch from drive shaft and bang it on and hope I can line up the holes that the bolt goes through both pieces?
File down some apparent rough sports, the clutch first because the other end is nice and shiny?
Any advice would be helpful, thank you.
20200603_183049
.jpg
1.4MB
1,774
I don’t 100% understand what happened but if you are saying the PTO shaft separated then you need to get the inner shaft turned into the same orientation as the outer shaft. They will only fit together in one way. For example there are triangular shapes and have to be rotated 120 degrees until the two halves are able to fit together.
Hope that makes sense
old and tired
L2800 HST; 2005; R4
I think the OP is talking about near the gear box where a slip clutch attaches. My "slip clutch" never slips, I shear the bolts that hold the "slip clutch" on to the gear box.
Look to see if there is a burr that needs to be filed down...
Technical Ted
L3560/cab LA805 loader LandPride RCF2060 rotary cutter, HLA hyd angle snow blade
Jul 2, 2016
105
Dansville NY
Not sure if I understand what you're saying 100%, but there are instructions on how to set the tension on the clutch so it will slip correctly. When I adjusted mine when I first got it, it was too tight. Hopefully, I have it set correctly now so it will slip rather than shear bolts.
Ted
3,342
Yes, agree with Ted. Sounds like “old and tired” has his clutch-bolts too tight and his clutch is unable to slip.... if he’s losing shear bolts instead.
There is a video of “slipping the clutch” which should be done each year to confirm the clutch is working properly. TractorMike on you tube, things you should do to your rotary cutter. https://www.youtube.com/watch?v=eVRr9eechLI
old and tired
L2800 HST; 2005; R4
Yes, you are both correct... :eek: :p my slip clutch has never been adjusted. Adjusting it is one of the last projects on my todo list... which is long. I should be retired in a couple of years and then I'll have plenty of time to adjust it. Until then, I'll rely on a $0.59 bolt to protect the gear box.
Just for the fun of it, this mower, LandPride, was originally bought for $250 to "find" all the hidden treasures in my pasture. After that, I would buy a good mower but it turns out, this IS a good mower.
The mower mainly turns big rocks into gravel (or at least smaller rocks). I have started to re-skin the old girl as she started to rust out pretty badly. Seems re-skinning her is higher on the todo list than adjusting her slip clutch.
