Land plane
ferguson
L3130
Jan 19, 2022
319
124
w.v.
Bulding a land plain question / cutting angles/ do they protrude go below the plaining edge 1/4" yes no ??
2manybikes
19 L3560 HST with cab.
Aug 2, 2021
62
32
SW Va.
Yes. My BEFCO BGS072 is adjustable. I would suggest you consider that in your design. Im not sure what my max is, but I would guess mine is down at least that much and does some serious cutting on my driveway. It is my favorite tractor implement. I have LONG gravel driveway.
Daisy Cutter
L2501 w/ssqt fel,60" LP finish mower, 54" LP grapple, and 48" BushHog box blade
Oct 6, 2019
Priceville AL
Please post pics as you go. I've been planning to build one for a while.
bearskinner
Sep 1, 2014
926
241
N. Idaho
I posted building one about 5 years ago. I placed my Blades at 5/8” below the side rails
jimh406
Kubota L2501 with R4 tires
Jan 29, 2021
2,572
2,027
Western MT
You definitely want it to be adjustable if for no other reason that to adjust for wear.
8,785
Bearskinner used my build as his copy, his looks way better than mine.
The blades are 1/2 to 3/4 deeper than the side rails.
The blades are the same angle and about 30 degrees, it really doesn't matter much.
Use hardened steel , AR400 or better for the blades and they will outlast you!
ferguson
L3130
Jan 19, 2022
319
124
w.v.
Will make it adj, at some point in time / going to use a 2x4x1/4 lentle for front blade & 2x2 back blade / so far only welding wire & time
