Removed my front blower this spring and a female QA (Red-D-Down) for fel was leaking. Replaced with oem and sold my snow pusher. I loaded on the buyers trailer. Everything ok, then installed my bucket and noticed when I lower it’s slow. Raise rpms and thought it was quicker but it’s debatable.
Compared with my neighbors L3560HSTC and his works like mine use to.
Almost acts like it’s on the edge of adjustment.
update———
I disconnected QA and checked inside fittings-ok.
Seemed fine but after warm up slow moving down. Pulled boot off fel lever and lubricated at lever and at trans.
it works normal if I push hard forward, Twice as much pressure than up.
Two odd observations.
1. If I lock lever it’s in raising mode, slightly.
2. I no longer feel detent for float mode. Previous it had a click feel.
3. Looking at service manual and I don’t think it’s the front loader control valve assembly because FEL lever feels like it has too much forward and rearward play. Can’t find anything in service manual on adjusting the lever?
Thoughts? Thanks
update———
Thoughts? Thanks
