LA524 Loader Bucker tilt cylinder leaking / Rebuild or replace ?
bowbender6
9
union city, mi, branch
Today I noticed a small leak coming out of the rod end around the threads of the cap on left hand cylinder that controls the tilt of the bucket. If I put a 10 'straight edge on the rod it I can see about a small gap (about .100") so the rod got bent.
My question is;
Can the rod be straightened?
or buy a new rod and rebuild kit?
or buy a new cylinder?
Thanks
7,387
I’m no expert, but from what I’ve read here on OTT
YES
NO/YES
NO
I’m being a smartass…
There’s guys that have done many rebuilds. The challenge for someone without the proper tools will be straightening the rod.
An alternative may be an hydraulic shop that does this sort of thing. Many here report they have better luck letting a pro rebuild cylinders instead of replacing or tackling it themselves. Cheaper than replacement and more efficient than struggling with it themselves.
Pau7220
Aug 1, 2017
786
281
Clarks Summit, PA
Rod can be straightened depending on how bad... Apparently Kubota says no. I've personally done it many times... hydraulic shops do it all day.
Seriously, remove it and take it to your local hydraulic shop. Chances are they'll do the whole job for less than the cost of seals from the dealer. And you can't roll the seal into the gland without the tool to do it (the one that is leaking at the rod).
7,387
Pau7220 obviously has the experience while I don’t.
I often wanted to try a rebuild when/if needed, but my issue would be having time to do it, and needing a get the cylinder back in service ASAP.
PoTreeBoy
L35 Ford 3930
Mar 24, 2020
4,110
2,533
WestTn/NoMs
I'm with rcw and pau - take it to a shop and let them straighten it and install new seals.
Now for your lecture. You probably bent the rod back dragging with the bucket rolled down. This puts a lot of compression load on the rods while they are most extended. Like a long column, they collapse under the excessive load.
You may want to check the cylinder on the other side to see if it's bent also, while you're at it.
bowbender6
9
I would guess I did it. The other side seems straight. I have learned to be careful ( the hard way) but I still ain't there yet.
Thanks
5,515
2,231
it can be straightened but it will bend again. Also when it gets bent the hardened outer "case" of the shaft will crack (every time). You might not see or feel it but it does. I've bent them back by request but they usually bend again, or break in some cases. Some get lucky.
also when they are "bent back" the runout should be within a few thousandths of an inch. Most places can't get them anywhere near that close.
WAS BANNED FOR NSFW PICS
5,164
I had a local hydraulic shop rebuild my cylinders, but they said to get the kits from Kubota, because they sometimes can't find the exact seals necessary. They offered to take it apart to see if they had seals that would fit, and if they didn't, then I would still have to get Kubota seals, and instead of having it take a day before I would get it back, it would be waiting till I could deliver the Kubota kit. Considering that they are 30 miles away, I brought them the kits. Went to a local restaurant for lunch, and when I got back, they were ready to pick up.
