I have a 1995 B2150HST. The 3 point is fully operational. The loader will not go up, but does go down. It also still rotates the bucket up/down. This all started after I let the hydraulic fluid get ridiculously low: almost 4 Qts low. Below are things I have checked so far, but I am a novice at best. I've had the tractor for 10 years.
- filled with fluid, started it for a few minutes and then added more. I've checked it several times and the fluid level is good.
- loosen air bleeding bolt on the Hydraulic Block Type Output
- remove and reconnect all quick disconnect connections
- removed flow priority valve and inspect/verify spring is functional
- checked position of directional valve (strangely enough it is fully CCW, which is incorrect according to the manual? When in the correct position, nothing on the bucket works. I have never ever adjusted this until today when this problem started.
see attached photos. The tractor came with an auxilliary control valve - see photo of connection diagram. Any ideas what could cause this? I thought about bypassing the AUX valve, but since the bucket rotates up/down, that doesn't seem to be the problem? maybe the relief valve in the loader control valve???
Thanks for any help that can be provided.
Greg
Greg
