LA211 Loader Hose Replacement
Mark8076
BX2200
Mar 20, 2023
I had a hydraulic line crack on my LA211 loader. It looks like I will need to do a lot of disassembly at the control block end to be able to get a wrench on the hose fittings???
Does anyone know of instructions on-line for doing this?
9,684
Nope, just the WSM and it will just say remove lines.
cthomas
LX2610 HSDC
Jan 1, 2017
848
563
La Farge Wi
If written by Alldata it would go something like this.
1. Remove lines from loader 2. Replace lines as needed 3. Reassemble is the reverse of removal.
Ok sarcasm is over, take pictures and label bolts(I use cupcake tins and post it notes). Penetrating oil on fittings is your friend. Flare wrenches are very helpful. Also, I have use an induction heater on rusted fittings(brake lines) with some success(usually I see them after others have really screwed it up). If needed new vise grips come in handy sometimes, but, last resort.
