La 852 loader
Mx5000
Kubota mx5000
Jun 25, 2018
11
Ohatchee, Alabama, USA
Hello all, I have an MX5000 and I am in search of a loader for it. My tractor has the lines, controls and the brackets already on it but the previous owner sold the loader. I understand that the La 852 is the correct loader for it but are there any others that will fit with little to no modification. Thanks
8,216
Looks like the only 2 loaders in that class or size are LA852-2 and LB702.
freewheel3
MX5000DT LA852, BX1800D, B6000DT, B6200HSTD, B7100HSTD, L185, T1700HX, ZD1211
Mar 9, 2013
333
Alberta
Do you know what the difference is between the two? I need to order a loader for my MX5000, and not sure which one to get.
8,216
You would want the LA852-2 loader, but it may not be available any longer.
freewheel3
Mar 9, 2013
333
Alberta
Thanks, NIW. I went with the LA852, my dealer says the 702 is no longer available. I haven't had a chance to try it out yet as the tractor is still at the dealer waiting on a hydraulic valve kit for a set of remotes to the rear.
The previous owner had installed some kind of homemade setup on it but you had to close a valve he installed to use it. But with the valve closed, the 3pt wouldn't work and vice versa, so I ordered a factory setup.
