L650 backhoe - need measurements
aribert
L295DT
Dec 10, 2018
Metro Detroit, MI, USA
Greetings:
The seals are shot on my late father's backhoe and I intend to rebuild the problem cylinders. To do so, I will need a pin spanner to unscrew the cylinder endcaps. I have the metalworking tools to make my own spanner but the backhoe is 1000 miles from my location.
So if you happen to own or have access to a L650, I am interested in the diameter of the endcaps and also the diameter of the pin holes on the endcaps. Please look at the yellow circles on the attached images for the endcaps that I am looking for dimensions of. For the cap diameter, tape measure within an 1/8th of an inch should be OK. I suspect many of these cylinders will have a common endcap dia / pin hole dia.
TIA
[/ATTACH]
shootem604
Apr 23, 2018
874
British Columbia
A few years ago we made up a tool for removing endcaps on cylinders. I think they were on a boom lift. I might still have it kicking around, but not sure if it is a standardized sizing.
3,586
Can't help with dimensions, but see your other post for dis-assembly.
