Hi all,
The fitting(s) on the bottom-right quick connect for my mid-PTO hydraulic set sprung a pretty good leak (must have rattled loose? (L6060 has 10 hours on it so probably still working out the kinks) and it's not obvious to me how to tighten them as there appears to be two retaining nuts separated by a colored ring. I included some pictures for reference and I realize the picture of the retaining nuts is for the top left qc and it was much easier to snap a picture of that one for reference. Thankfully the tractor was not running when the leak sprung.
I have a few questions that I'll be asking the dealer Monday and will update you all with the fix - if you have answers or suggestions I'd love to hear them too.
* I've been trying to read through the operating manual to see how to check the hydraulic fluid level as it is definitely low - I see reference to transmission fluid but not hydraulic - does the transmission share the fluid with the loader and PTO or have I just not seen it in the manual yet?
* How do I appropriately tighten these fittings/nuts?
* After properly tightening and adding hydraulic fluid are there any required procedures such as bleeding or waiting/re-checking?
* I presume the proper hydraulic fluid specs are in the operating manual
thank you.
thank you.
