L60 Drop Drawbar option
kubotafreak
Sep 20, 2018
1,049
395
Arkansas, US
Looks like kubota just released a new wholegoods item. (L6850 $93) Interested if anyone has purchased yet. Should fix the issues for those trying to use smaller batwings with the 50-60hp l60.
SDT
multiple and various
Apr 15, 2018
3,311
1,101
SE, IN
Hitch is going to be close to the ground.
SDT
kubotafreak
Sep 20, 2018
1,049
395
Arkansas, US
SDT
No doubt there.. It is definitely an after thought fix for the issue of the drawbar to pto spacing being too small. I have not seen one in person, but I cant imagine it being much more than 1.5-2" drop. Hopefully it will also correct the issue with drawbar length as well on the l6060 for the 14".
kubotafreak
Sep 20, 2018
1,049
395
Arkansas, US
I took receipt of my new l6060 cab. I can confirm the drop drawbar gives you a 14" pto tip to pin hole spacing and is a 4" drop so should have plenty of vertical clearance. With the factory 28" ag tires I have 16" ground to bottom of drop drawbar. This drawbar will fix the issue with kubota gl60 tractors and the pto spacing. The l6060 has the least pto to pin length, if you have one of the lower hp models(l47,40,35) your pto to pin spacing will be larger.
GEM1N1
MX6000
Aug 4, 2023
KANSAS CITY
I've tried two Kubota dealers and they say this part number doesn't exist. I'm trying to get my new batwing hooked up and need an offset drop bar to make it work. Can you tell me where you purchased it?
kubotafreak
Sep 20, 2018
1,049
395
Arkansas, US
Dealer from arkansas. Springdale tractor
That is a whole-good number so you need to speak to a salesman.
GEM1N1
MX6000
Aug 4, 2023
KANSAS CITY
Finally found it on Messick's website. It wouldn't pull up when I had my MX6000 tractor in the system. Had to take it out and plug in L6060. Thanks!
