The manual for the L5030 says that the hydraulic and transmission fluid filters should be changed every 200 hours (pp. 80-81), but the fluid itself should only be changed every 400 hours (p. 84).
This implies that when you change the filters, you do not fully drain the fluid. Yet the instructions for changing the filters say to drain the fluid in just the same way as the instructions for replacing the fluid itself.
What gives? Do you change the fluid and filters together every 200 hours on the HST? Or can/do you change the filters without first draining the fluid? Or do you drain the fluid only partly before changing the filters?
Any ideas?
Many thanks,
mebota
Any ideas?
Many thanks,
mebota
