L5030 front end loader, snowblower question
Jayhawk238
2004 L5030 HST/CAB
Oct 30, 2010
97
10
Featherville, ID, United States
Some where I read a post with pictures where I could install a front end loader on my Grand L5030 without having to remove my Kubota front mounted snow blower sub-frame. Anyone know where I can find that post? :confused:
VermontMike
Kubota 5740 Grand, FEL, Rotary Brush Cutter, Box Blade, Front mount Snow Thrower
JayHawk,
I recently purchased a new Grand L5740. I took delivery in the winter so I had the snowblower mounted and attached at the dealer. I recently removed the snowblower from the tractor leaving the sub-frame attached. I was able to attach and operate the FEL with no problems. The down side is that the sub-frame sits very low to the ground and you get almost no ground clearance as a result. This is a real problem on rough ground! I am planning to remove the sub-frame at the earliest and am wondering if anyone can provide insight as to how difficult this is. It looks pretty straightforward though a bit on the heavy side for a one man job.
Mike
