L48 seat safety switch
tims
9540 L48
Feb 26, 2013
29
DeMotte In
Went to spin the seat around from back hoe to tractor and it had a catch/stop about 1/2 way around, and naturally just kept pushing harder till it turned all the way. When I went to go forward it would stall out when the shuttle (Forward /reverse pedal) was pushed down too far. If we rev up the rpm it will move,but when you push the pedal just a little it stalls, out,unless you let off quick enough, and it will recover. I think we pulled a wire loose or apart. Put a continuity tester on the leads pulled off the sensor on the bottom of the seat, and it showed an open curcuit. Any ideas.
thnx
Tims
