I bought an L48 tractor last year.
I can’t run unit for long periods, once it gets up to operating temp tractor doesn’t have enough power to move. . I have to let it sit and cool off then it will move. So I changed hystat oil and filter, didn’t change anything. Oil doesn’t get hot.
I checked charge pressure and found 100 psi at high idle.
I inspected charge relief valve. I shimmed it up and was able to achieve 220 psi but that’s as high as I could get it to go. Spec is around 370.
I believe I might have an internal leak.
Has anyone ran into this or have any thoughts as to where I should look next.
Thank you!!!
Thank you!!!
