L4610 Starting problem please read
mopar2ya
104
ontario canada
Sometimes when I try to start my L4610 I have to get out and shake wires near starter. I have lights on dash but does not turn over. Looks kind of tight in there to get at. Any suggestions before I start taking it apart???
200mph
Mar 3, 2017
1,228
65
PA
If you follow the good advice above (remove wire and clean the mating surfaces to bare shinny metal) and the problem isn't resolved consider the following.
It could be the wire terminal to wire interface that is either corroded or not making good contact with each other.
If you're handy with a volt meter it could help pinpoint the faulty wire(s).
Good luck
