L4610 hydraulic fluid
GreasedMonkey
Varina,Va
How can I figure out if Mobil DTE 10 Exel 46 hydraulic fluid will work in my Kubota L-4610 tractor? I've got three buckets in the garage and don't really want to go buy more buckets to put in the garage LOL PLEASE HELP THANK YOU in advance and if it won't work what's the cheapest hydraulic fluid that I can use?
Grease Monkey out
swampFOXX
L4610
Nov 9, 2016
9
Princess Anne
Re: L-4610 hydraulic fluid
I've used the Napa utf from what I read it meets the requirements. I don't know about your Mobil one but you could compare the two
Sent from my SM-N910V using Tapatalk
GreasedMonkey
Varina,Va
This stuff I've got goes in one of my other tractors & is really expensive. How do I figure out if it'll work in my Kubota?
rbargeron
Jul 6, 2015
1,183
260
western ma
Are your tractors both hydrostatic?
kevinj
L3940hstc - B7500hst - BX1860 - Farmall 560D - Farmall M
Jun 4, 2018
101
Typically you would read the spec sheet for compatibility.
Not much I know of that meets super udt2
10,008
Considering your tractor is either a GST or an HST I wouldn't use it, they are a lot pickier than a geared transmission.
Mystik JT-5 is a great economical UDT fluid, I use it in all of my equipment, and yes I also have a GST tractor. ;)
GreasedMonkey
Varina,Va
Where can I look at the spec sheets? What Kubota recommends and compare it to my Mobil 1 oil
kevinj
Jun 4, 2018
101
Google this - Mobil DTE 10 Exel 46
What Kubota recommends is in your manual & I think they also show maintenance stuff on their website
Oh, and for the best help give the rest of the model number, see Wolfmans post
