B billmalzewski New member Equipment L4350DT Apr 18, 2018 6 0 0 Burlington Wisconsin USA Apr 18, 2018 #1 Anyone familiar with a noise coming from the Clutch housing on a L4350DT or similar model? It almost sounds like a lifter but is definitely coming from CLutch area not motor. Any help is greatly appreciated.
North Idaho Wolfman Moderator Staff member Lifetime Member Equipment L3450DT-GST, Woods FEL, B7100 HSD, FEL, 60" SB, 743 Bobcat with V2203, and more Jun 9, 2013 34,099 9,288 113 Sandpoint, ID Apr 18, 2018 #2 Probably the throw out bearing, does the noise change when you step on the clutch pedal?
B billmalzewski New member Equipment L4350DT Apr 18, 2018 6 0 0 Burlington Wisconsin USA Apr 23, 2018 #3 No the noise only changes with revs on the engine, it is very consistent and pretty loud.
North Idaho Wolfman Moderator Staff member Lifetime Member Equipment L3450DT-GST, Woods FEL, B7100 HSD, FEL, 60" SB, 743 Bobcat with V2203, and more Jun 9, 2013 34,099 9,288 113 Sandpoint, ID Apr 23, 2018 #4 Next guess would be that the clutch or pressure plate is coming undone.
