I have an L4350 tractor. It has a V2203 engine that I transplanted into the tractor. Initial start up went without a hitch. Idles and accelerates fine. After a few seconds of run time it develops a fuel knock. Injection pump shims are most likely not correct, there was a lot of time between removing and reinstalling.
The tractor has a loader attached. I probably need to get a handle on injection pump timing.
I would like to know if I have a port to view the flywheel timing marks, I can’t seem to find anything. Before the loader was attached I looked for timing marks thru the large six bolt holes on each side of the bell housing, didn’t see anything.
What is the general rule regarding advance or retarding of injection pump timing? Do I add or remove shims.
Thanks in advance
DaveS
Thanks in advance
DaveS
