L4200HST Oil filter bursts
luebb
L4200 HST!
Jun 1, 2023
15
Germany, Cuxhaven
Hello!
My L4200HST is killing HST oil filters. I use new oil and new filters. Could I be the HST relief valve? Where is it located? Do I have do drain the complete Oil before checking the valve? Could it be anything else?
Please help. I have the L4240HST service manual, but there are so many changes it doesn't really help at all.
11,559
Start by reading the right WSM for the tractor.
Look at the envelope top right of the screen to help you out. ;)
3,102
First question, what brand filter are you using?
wdlanning
L3750, L4310, B20, Genie Boom
Nov 7, 2016
224
11
philadelphia pa
Hello!
Your vent is stopped up or plugged
whitetiger
Nov 20, 2011
3,851
2,243
Kansas City, KS
Check the Charge Pressure relief valve for sticking or debris restricting the fluid flow through it.
The" vent" would not affect it in any way.
wdlanning
Nov 7, 2016
224
11
philadelphia pa
If it’s over-pressurizing the filter is the weak link. Remove the filler cap and run it Probably won’t fail
luebb
L4200 HST!
Jun 1, 2023
15
Germany, Cuxhaven
Oh! One thing I forgot to say: The top speed I can reach is 17km/h instead of 25km/h. I think it could be related to the same issue.
11,559
It's not a sump or case overpressure issue, it's a closed controlled pressure loop issue.
So the vent and the cap has no bearing on it.
luebb
L4200 HST!
Jun 1, 2023
15
Germany, Cuxhaven
I've found a book called "WSM Tractor mechanism" in german. Its not specific to my tractor, its for all Kubota tractors with all kinds of hydraulics, brakes, steerings, transmissions and so on. I've found an HST transmission in this book, which is absolutely similar to mine. With those drawings i've found the Charge Pressure relief valve and an extra relief valve for the filter, right next to the Charge Pressure relief valve.
I checked both of them. The Filter valve had a very very little dirt (maybe, not sure) and two shims - but the Charge Pressure relief valve had 10 shims and popped out of the thread due to the spring tension!!!
Maybe the preowner just wanted too much charge pressure? I reduced them to 5 shims to give it a try.
What do you think?
11,559
What do you think?
Sounds like your on the right path!
luebb
L4200 HST!
Jun 1, 2023
15
Germany, Cuxhaven
Good news!
I reduced the shims of the charge pressure relief valve from 10 to 5 - and the shims of the filter protection relief valve from 2 to zero. Works like a charm. And surprisingly I think I reduced the diesel consumption somehow close to half! Can't really imagine that by myself. o_O
11,559
Good news!
Excellent job!
