L4200 radiator replacement.
David wallace
B7100, b6100, l4200, gerrett 15 skidder, jd350 dozer, jd 440d loader, and more
Jan 16, 2023
Oregon
Had the radiator stolen from a project L4200 It's a open cab, and base model shuttle shift.
I'm finding oems as a 3 core and aftermarkets as a 2 core. With a massive price difference between the 2 types.
Was it one radiator part number, for with or without the cab? As obviously the cab ac would load the cooling system far more then a open cab.
They luckily left the fan shroud.
Primary use will be loader work.
In a mild coastal climate.
Mabe some pto use but nothing pushing the engines limits. Finding a backhoe to help as a counter balance would be up there on the most interested items. But it is a one speed pto, so no using 2nd or 3rd speed to keep engine rpms down.
Made this little walk around video of it, when we first got it.
8,713
It's 42hp tractor with 37hp to the PTO.
The radiator is the same regardless of cab or not.
The tire sizes are stock, it was offered in several size tire combinations.
