L4060 PTO problem power takeoff
GBJeffOH
L4060, EA Grapple, 6' LP Brush Hog, 8' snow plow, 6' LP tiller, EA Forks, Spraye
Nov 17, 2014
316
137
Jefferson, Ohio
gbjeffoh, I've been following this post for a while and got notified of your response today. Has yours been bothering for 3 or 4 years like mine has. They replaced my solenoid and it helped. If I idle the tractor down for about a minute it will shut down "most" times when I push the PTO button. Did removing the check valve fix yours 100%. And what is that unit the check vale is in?
I have not had any issues since I removed the check valve. I put about 300 hours a year on it. Maybe 150 using the PTO. It shuts off right away every time.
It is the PTO clutch solenoid valve.
It is on the RH side. Just a little farther back than the back of the fuel tank.
I pulled the fuel tank to get to it. You might not half to.
This should be a recall.
GBJeffOH
Nov 17, 2014
316
137
Jefferson, Ohio
I just figured out Below serial 44944 has the check valve. Above does not.
Dennis.D
L6060, Erskine hydraulic snow blower, back hoe
Feb 16, 2018
148
59
Central, ME,USA
Mine is a Gr L6060. should I start with a pressure test first. The dealer did a pressure test and said is was in specs. But my problem is the same as yours. The longer I run it with PTO on the more apt it is to not shut off when I disengage the pto switch. Sounds like the same problem just a different model tractor.
GBJeffOH
Nov 17, 2014
316
137
Jefferson, Ohio
I put a gauge with a long hose so I could watch it. It was normal for maybe 30 minutes then got real high.
I would go to messicks with the serial number to see if the check valve is there.
GBJeffOH
Nov 17, 2014
316
137
Jefferson, Ohio
https://www.messicks.com/catalogs/k...lve-component-parts-old-s-no-44944-s-no-44944
https://www.messicks.com/catalogs/k...lve-component-parts-new-s-no-44945-s-no-44945
If your serial number is below 44944 you need to remove the ball.
