L3901 3 point lift height
OldcrowP51
Kubota L3901HST, RCR1860 rotary cutter
Aug 18, 2021
90
29
Minnesota
The 3 point on my tractor doesn't seem to go as high as it used to.
It has been well documented by others how a quick attach hitch will hit the rear marker lights.
Currently mine won't go that far.
Is there some type of limit switch effecting lift height?
jyoutz
Jan 14, 2019
3,624
2,718
Edgewood, New Mexico
Did you change the hole that your top link is attached to?
whitetiger
Nov 20, 2011
3,679
2,095
Kansas City, KS
Raise the 3-point hitch fully, then lift the 3-point arms by hand to see how much more they will raise before hitting the stop.
If they can be lifted more than 3/4" measured at the end of the arm on the rock shaft, they can be adjusted on the LH side.
11,051
Also a maladjusted feedback linkage can also cause the three point to not reach its full height.
