Today while using a rotary mower behind my L3800, (415 hrs on hour meter) it started to loose power, running rough, and blowing some white smoke. I shut the mower down, slowed the engine down to an idle and headed for the shop.
I changed the fuel filter, and made sure I had a full stream from the fuel tank, oil and water levels were where they should be. Strarted the tractor back up and it would idle just fine, at wide open throttle after while it would start to lose rpm's and stumble just a little bit but not as bad as it was before I changed the fuel filter.
The fuel was fresh about a week ago. I'm not very good at working on diesels, where should I look next? or what should I do next?
Any ideas or suggestions would be appreciated, Thanks, Jim
