L3650GST Bubble Gauge
bobkubota
L3650GST Loader & Backhoe
Jan 30, 2013
10
Corning, ohio
The bubble gauge on my L3650GST used to check the hydraulic fluid is no longer clear. This is not a problem with the fluid becoming milky but rather the gauge lens is just no longer clear enough to see the fluid level.
Is this problem common?
Is it hard to repair?
My L3650GTS was purchased used 4 years ago and has been an excellent machine. Tractor was made in 1993.
Thank you. bob
lreops
L3400DT W/ LA463 FEL and L235DT W/ BF400 Loader
Dec 26, 2011
306
Rising Sun, Maryland
Assuming that most sight glass/gauge are basically the same, they just pop out and pop in. Just have one when you do your next fluid change. Simple fix.
Ron
bobkubota
Jan 30, 2013
10
Corning, ohio
Thank you for the reply. I'll call the Kubota dealer and get one ordered.
This should be something I can do.
bob
GWD
M7040, L48 TLB, BX2200
Jan 8, 2010
792
Northern California
Make sure that the fluid level is not so high that the bright white background is "yellowish" from the fluid.
Park the tractor on a slope with the sight glass on the uphill side. If the background is now bright white then the problem is a simple overfill issue.
My L3650-DT kept a clear sight glass the entire 28 years that I had it. Once, I overfilled it and was quite confused until it was parked on the side of a steep hill.
bosshogg
2004 L3400F w/ FEL
Aug 16, 2012
231
Hartford, SD, USA
Great advice...I ran into the same problem because I overfilled it. Shining a flashlight into the bubble also helps to tell if your staring at fluid or empty space.
bobkubota
Jan 30, 2013
10
Corning, ohio
All of your replies have been very informative.
The lens in the gauge has been the same dull white since I purchased the tractor 4 years ago. I know the tractor was low on hydraulic fluid a few days ago as it was not running the lift without making a noise. I added 1 1/2 gallon of fluid and that solved the issue. I saw no difference in the gauge. My believe is the bubble lens is simply discolored.
There have been some hydraulic line leaks and fluid has been added from time to time.
I will try shining a flashlight on it and see if the fluid becomes visible.
The replacement gauge has been order and I feel confident that I can change it.
Again thanks for all of the replies.
bob
bosshogg
2004 L3400F w/ FEL
Aug 16, 2012
231
Hartford, SD, USA
bob
Another poster once stated to park the tractor on a hill sideways with the bubble on the high side to prevent fluid from running out while changing. I thought it sounded like a good idea.
GWD
Jan 8, 2010
792
Northern California
It will be very interesting to see how this all turns out.
Be sure to post back on what outcome resulted.
5,652
Well now that you mention it I did meet her in phyc hospital
