L3650 Shutdown Timer T0070-31410
Pau7220
Aug 1, 2017
785
279
Scranton, PA
Just as a FYI to save someone else some time and money. This part is a direct replacement for the above Kubota part number... at less than half the price. Pulling up the picture on the Messicks page is the Denso part # 061700-3770. This is the supersession in a full solid state version. More markup here than jewelry!!
BTW... It worked purrfectly !!
200mph
Mar 3, 2017
1,228
65
PA
It is very kind of you to post this info and I'm certain others will appreciate your effort in the future!
Adding the following information below in the event it helps future members find this info when conducting searches.
Of the 167 models this part fits, it does not include your L3560 :confused:. It's crazy the references to what it fits aren't better.
This part is used in a lot of models according to Messick's and Replaces 31351-31410, 31351-31413, 31351-31412
The part fits the 167 models listed below:
440-4WD 24.8HP KUBOTA DIESEL
440-4WD 32.5HP KUBOTA GAS
440-4WD KUBOTA DIESEL (S/N 000400 AND ABOVE)
440-4WD KUBOTA GAS (S/N 000302 AND ABOVE)
450 24.8HP KUBOTA DIESEL
B1550D (4wd) - T04201 PANEL / SWITCH [A AU]
B1550D (4wd) - T04202 PANEL / SWITCH [CA]
B1550E (2wd)
B1550HST-D (Hydrostatic Transmission, 4wd) - T04201 PANEL/SWITCH [A] [AU] [NZ]
B1550HST-D (Hydrostatic Transmission, 4wd) - T04202 PANEL/SWITCH [CA]
B1550HST-E (Hydrostatic Transmission, 2wd)
B1750D (4wd) - T04201 PANEL / SWITCH [A AU]
B1750D (4wd) - T04202 PANEL / SWITCH [CA]
B1750E (2wd)
B1750HST-D (Hydrostatic Transmission, 4wd) - T04201 PANEL/SWITCH [A] [AU] [NZ]
B1750HST-D (Hydrostatic Transmission, 4wd) - T04202 PANEL/SWITCH [CA]
B1750HST-E (Hydrostatic Transmission, 2wd)
B2150D (4wd)
B2150E (2wd)
B2150HSD (Hydrostatic Transmission, 4wd)
B2150HSE (Hydrostatic Transmission, 2wd)
B7410D (4wd)
BX1500D
BX1800D - B21501 SWITCH/SENSOR
BX1800D - B21502 SWITCH/SENSOR
BX1830D
BX1850D
BX1860
BX1870
BX1870-1
BX1880
BX2200D - B21501 SWITCH/SENSOR
BX2200D - B21502 SWITCH/SENSOR
BX2230D
BX2350D
BX2360
BX2370
BX2370-1
BX2380
BX23D
BX23S
BX24D
BX25
BX25DLB
BX25DLB-1
BX2660D
BX2670
BX2670-1
BX2680
G2160 / G2160-DS / G2160AU - B10001 ELECTRICAL PARTS [G2160/G2160-DS]
G2160 / G2160-DS / G2160AU - B10002 ELECTRICAL PARTS [G2160AU/G2160EC/G2160UK]
GR2100
GR2110
GR2120 (Turf tires)
GR2120-2
GR2120B (Bar tires)
GR2120B-2
KH-191
L2900DT
L2900DT (Dual Traction 4wd)
L2900DT-GST
L2900DT-GST (Glide shift transmission, 4wd)
L2900F
L2900F (2wd)
L3010DT / GST / HST - B10201 SWITCH 1 [EXCEPT HST TYPE]
L3010DT / GST / HST - B10202 SWITCH 1 [HST TYPE]
L3010DT / GST / HST (4wd) - B10201 SWITCH 1 [EXCEPT HST TYPE]
L3010DT / GST / HST (4wd) - B10202 SWITCH 1 [HST TYPE]
L3010F (2wd)
L3300DT (Dual Traction 4wd)
L3300DT-GST (Glide shift transmission, 4wd)
L3300F (2wd)
L3410DT / GST / HST (4wd) - B10201 SWITCH 1 [EXCEPT HST TYPE]
L3410DT / GST / HST (4wd) - B10202 SWITCH 1 [HST TYPE]
L35
L3600DT
L3600DT (Dual Traction 4wd, Rops)
L3600DT-C
L3600DT-C (Dual Traction 4wd, Cab)
L3600DT-GST
L3600DT-GST (Glide shift transmission, 4wd / Rops)
L3600DT-GST-C
L3600DT-GST-C (Glide shift transmission, 4wd / Cab)
L3710DT / GST / HST - B10201 SWITCH 1 [EXCEPT HST TYPE] [ROPS TYPE] [OLD TYPE] ## [EXCEPTE TYPE CABINE] [TYPE VIEUX]
L3710DT / GST / HST - B10202 SWITCH 1 [EXCEPT HST TYPE] [ROPS TYPE] [NEW TYPE] ## [EXCEPTE TYPE CABINE] [TYPE NOUVEAU]
L3710DT / GST / HST - B10203 SWITCH 1 [HST TYPE] [ROPS TYPE] [OLD TYPE] ## [TYPE VIEUX]
L3710DT / GST / HST - B10204 SWITCH 1 [HST TYPE] [ROPS TYPE] [NEW TYPE] ## [TYPE NOUVEAU]
L3710DT / GST / HST (Rops) - B10201 SWITCH 1 [EXCEPT HST TYPE] [ROPS TYPE] [OLD TYPE]
L3710DT / GST / HST (Rops) - B10202 SWITCH 1 [EXCEPT HST TYPE] [ROPS TYPE] [NEW TYPE]
L3710DT / GST / HST (Rops) - B10203 SWITCH 1 [HST TYPE] [ROPS TYPE] [OLD TYPE]
L3710DT / GST / HST (Rops) - B10204 SWITCH 1 [HST TYPE] [ROPS TYPE] [NEW TYPE]
L3710DT-HST-C - B10206 SWITCH 1 [A] [HST TYPE] [CAB TYPE] [OLD TYPE] ## [TYPE VIEUX]
L3710DT-HST-C - B10207 SWITCH 1 [A] [HST TYPE] [CAB TYPE] [NEW TYPE] ## [TYPE NOUVEAU]
L3710DT-HST-C - B10208 SWITCH 1 [CA] [HST TYPE] [CAB TYPE] [OLD TYPE] ## [TYPE VIEUX]
L3710DT-HST-C - B10209 SWITCH 1 [CA] [HST TYPE] [CAB TYPE] [NEW TYPE] ## [TYPE NOUVEAU]
L3710DT-HST-C (Cab) - B10206 SWITCH 1 [A] [HST TYPE] [CAB TYPE] [OLD TYPE]
L3710DT-HST-C (Cab) - B10207 SWITCH 1 [A] [HST TYPE] [CAB TYPE] [NEW TYPE]
L3710DT-HST-C (Cab) - B10208 SWITCH 1 [CA] [HST TYPE] [CAB TYPE] [OLD TYPE]
L3710DT-HST-C (Cab) - B10209 SWITCH 1 [CA] [HST TYPE] [CAB TYPE] [NEW TYPE]
L4200DT (Dual Traction 4wd, Rops)
L4200DT-C (Dual Traction 4wd, Cab)
L4200DT-GST (Glide shift transmission, 4wd / Rops)
L4200DT-GST-C (Glide shift transmission, 4wd / Cab)
L4200F (2wd , Rops)
L4200F-C (2wd, Cab)
L4200F-GST (Glide shift transmission, 2wd)
L4310DT / GST / HST (4wd, Rops) - B10201 SWITCH 1 [EXCEPT HST TYPE] [ROPS TYPE] [OLD TYPE]
L4310DT / GST / HST (4wd, Rops) - B10202 SWITCH 1 [EXCEPT HST TYPE] [ROPS TYPE] [NEW TYPE]
L4310DT / GST / HST (4wd, Rops) - B10203 SWITCH 1 [HST TYPE] [ROPS TYPE] [OLD TYPE]
L4310DT / GST / HST (4wd, Rops) - B10204 SWITCH 1 [HST TYPE] [ROPS TYPE] [NEW TYPE]
L4310DT-GST-C / HST-C - B10205 SWITCH 1 [GST TYPE] [CAB TYPE]
L4310DT-GST-C / HST-C - B10206 SWITCH 1 [A] [HST TYPE] [CAB TYPE] [OLD TYPE] ## [TYPE VIEUX]
L4310DT-GST-C / HST-C - B10207 SWITCH 1 [A] [HST TYPE] [CAB TYPE] [NEW TYPE] ## [TYPE NOUVEAU]
L4310DT-GST-C / HST-C - B10208 SWITCH 1 [CA] [HST TYPE] [CAB TYPE] [OLD TYPE] ## [TYPE VIEUX]
L4310DT-GST-C / HST-C - B10209 SWITCH 1 [CA] [HST TYPE] [CAB TYPE] [NEW TYPE] ## [TYPE NOUVEAU]
L4310DT-GST-C / HST-C (4wd, Cab) - B10205 SWITCH 1 [GST TYPE] [CAB TYPE]
L4310DT-GST-C / HST-C (4wd, Cab) - B10206 SWITCH 1 [A] [HST TYPE] [CAB TYPE] [OLD TYPE]
L4310DT-GST-C / HST-C (4wd, Cab) - B10207 SWITCH 1 [A] [HST TYPE] [CAB TYPE] [NEW TYPE]
L4310DT-GST-C / HST-C (4wd, Cab) - B10208 SWITCH 1 [CA] [HST TYPE] [CAB TYPE] [OLD TYPE]
L4310DT-GST-C / HST-C (4wd, Cab) - B10209 SWITCH 1 [CA] [HST TYPE] [CAB TYPE] [NEW TYPE]
L4310F (2wd) - B10201 SWITCH 1 [EXCEPT HST TYPE] [ROPS TYPE] [OLD TYPE]
L4310F (2wd) - B10202 SWITCH 1 [EXCEPT HST TYPE] [ROPS TYPE] [NEW TYPE]
L4350DT (Dual Traction 4wd)
L4610DT-GST (Glide shift transmission, 4wd)
L4610DT-HST (Hydrostatic Transmission, 4wd / Rops)
L4610DT-HST-C (Hydrostatic Transmission, 4wd / Cab) - B10203 SWITCH 1 [A] [CAB TYPE]
L4610DT-HST-C (Hydrostatic Transmission, 4wd / Cab) - B10204 SWITCH 1 [CA] [CAB TYPE]
L4850DT (Dual Traction 4wd)
L5450DT (Dual Traction 4wd)
M4030
M4030DT (Dual Traction, 4wd)
M4900 (2wd / Rops)
M4900-CAB (2wd / Cabin) - B13001 RELAY [OLD TYPE]
M4900-CAB (2wd / Cabin) - B13002 RELAY [NEW TYPE]
M4900DT (4wd / Rops)
M4900DT-CAB (4wd / Cabin) - B13003 RELAY [A] [OLD TYPE]
M4900DT-CAB (4wd / Cabin) - B13004 RELAY [A] [NEW TYPE]
M4900DT-CAB (4wd / Cabin) - B13005 RELAY [CA] [OLD TYPE]
M4900DT-CAB (4wd / Cabin) - B13006 RELAY [CA] [NEW TYPE]
M5030 (2wd)
M5030DT (Dual Traction, 4wd)
M5030SU (Special Utility, 2wd)
M5030SUMDT (Special Utility, Mechanical shuttle, 4wd)
M5700 (2wd / Rops)
M5700-CAB (2wd / Cabin) - B13001 RELAY [OLD TYPE]
M5700-CAB (2wd / Cabin) - B13002 RELAY [NEW TYPE]
M5700DT (Dual traction 4wd / Rops)
M5700DT-CAB (Dual traction 4wd / Cabin) - B13003 RELAY [A] [OLD TYPE]
M5700DT-CAB (Dual traction 4wd / Cabin) - B13004 RELAY [A] [NEW TYPE]
M5700DT-CAB (Dual traction 4wd / Cabin) - B13005 RELAY [CA] [OLD TYPE]
M5700DT-CAB (Dual traction 4wd / Cabin) - B13006 RELAY [CA] [NEW TYPE]
M5700DTN (Dual traction 4wd / Narrow / Rops)
M5700HD (Hydraulic Shuttle, 4wd / Rops)
M5700HDC (Hydraulic Shuttle, 4wd / Cabin)
M6800 / M6800S (2wd / Rops) - B01501 SWITCH/SENSOR [ROPS TYPE] [OLD TYPE]
M6800 / M6800S (2wd / Rops) - B10400 SWITCH(PANEL BOARD)/RELAY [ROPS TYPE] [NEW TYPE]
M6800DT / M6800SDT (Dual traction 4wd / Rops) - B01501 SWITCH/SENSOR [ROPS TYPE] [OLD TYPE]
M6800DT / M6800SDT (Dual traction 4wd / Rops) - B10400 SWITCH(PANEL BOARD)/RELAY [ROPS TYPE] [NEW TYPE]
M6800HD (Hydraulic Shuttle, 4wd / Rops)
M6800HDC (Hydraulic Shuttle, 4wd / Cabin) - B13001 RELAY [A] [CAB TYPE] [OLD TYPE]
M6800HDC (Hydraulic Shuttle, 4wd / Cabin) - B13002 RELAY [A] [CAB TYPE] [NEW TYPE]
M6800S-CAB (2wd / Cabin)
M6800SDT-CAB (Dual traction 4wd / Cabin) - B13002 RELAY [A] [CAB TYPE]
M6800SDT-CAB (Dual traction 4wd / Cabin) - B13003 RELAY [CA] [CAB TYPE]
M8200 (2wd / Rops)
M8200-CAB (2wd / Cabin)
M8200DT (4wd / Rops)
M8200DT-CAB (4wd / Cabin) - B13002 RELAY [A]
M8200DT-CAB (4wd / Cabin) - B13003 RELAY [CA]
M8200DTN / M8200SDTN (Dual traction 4wd / Narrow / Rops) - B10401 SWITCH(PANEL BOARD)/RELAY [ROPS TYPE] [OLD TYPE]
M8200DTN / M8200SDTN (Dual traction 4wd / Narrow / Rops) - B10402 SWITCH(PANEL BOARD)/RELAY [ROPS TYPE] [NEW TYPE]
M8200HD (Hydraulic Shuttle, 4wd / Rops)
M8200HDC (Hydraulic Shuttle, 4wd / Cabin)
M8200SDTN-CAB (Dual traction 4wd / Narrow / Cabin)
M9000 (2wd / Rops)
M9000-CAB (2wd / Cabin)
M9000DT (4wd / Rops)
M9000DT-CAB (4wd / Cabin) - B13002 RELAY [A]
M9000DT-CAB (4wd / Cabin) - B13003 RELAY [CA]
M9000DTL (4wd / Rops / Low Profile)
M9000DTM (4wd / Rops / Muddler)
M9000DTMC (4wd / Cabin / Muddler)
M9000HD (Hydraulic Shuttle, 4wd / Rops)
M9000HDC (Hydraulic Shuttle, 4wd / Cabin)
M9000HDL-F (Hydraulic Shuttle, 4wd / Rops / Low profile / Orchard)
R310BHOLD TYPE
R310OLD TYPE
R420
R520
RTV-X900G
RTV-X900R
RTV-X900W
RTV900G (General Purpose model 2004 - 2005)
RTV900G6 (General Purpose model 2006 - early 2009)
RTV900G9 (General Purpose model mid 2009 - early 2011)
RTV900R-SD / R-SDL (Worksite Realtree Hardwoods Camo model 2004 - 2005)
RTV900R6 (Worksite Realtree Hardwoods Camo model 2006-early 2009)
RTV900R9 (Worksite Realtree Hardwoods Camo model mid 2009 - early 2011)
RTV900T (Turf Utility model (with remote hydraulics) 2004)
RTV900T5-H / T2 (Turf Utility model (with remomte hydraulics) 2005 / Turf Tires)
RTV900T6 (Turf Utility model (with remote hydraulics) 2006-early 2009)
RTV900T9 (Turf Utility model (with remote hydraulics) mid 2009 - early 2011)
RTV900W (Worksite model 2004 - 2005)
RTV900W6
RTV900W6 (Worksite model 2006 - early 2009)
RTV900W6SE (Worksite model 2007 / Special Edition)
RTV900W8SE (Worksite model 2008 / Special Edition)
RTV900W9 (Worksite model mid 2009 - early 2011)
RTV900W9SE (Worksite model mid 2009 - early 2011 / Special Edition)
RTV900XTG (General Purpose model / XT)
RTV900XTR (Worksite Realtree Hardwoods Camo model / XT)
RTV900XTS (Worksite Orange with ?·Package (Special Alloys, Spray-on Bedliner, Speedometer) / XT)
RTV900XTT (Turf Utility model (with remote hydraulics) / XT)
RTV900XTW (Worksite Orange model / XT)
TG1860 (Diesel) - B50000 ELECTRICAL WIRING
TG1860 (Diesel) - B50001 WIRE HARNESS
Pau7220
Aug 1, 2017
785
279
Scranton, PA
It is a L3650DT GST which is on the list.
These 2 models are too easy to read and type wrong.... with a huge difference between models. Kubota's attempt at confusing us.
Thanks for adding the additional models.... it helps everyone else.
Pau7220
Aug 1, 2017
785
279
Scranton, PA
What exactly does this part do for the tractor?
It energizes the shutdown solenoid for about 5 seconds when the ignition is turned off.
Your L3560 is a different unit.
