L345 left steering arm
Stevn
Kubota l345
Jan 4, 2023
I can’t find a left steering knuckle for a L345 . It’s a discontinued idea. Even places that said they had it online do not have it. Parts places don’t have it . I can’t weld it because I don’t have the pieces. I need some help
8,207
eBay, craigslist, call different parts dealers.
It would also help not to be so vague when trying to find a part.
Like is the tractor a 2wd or 4wd, huge part difference.
Having the right name for the part is extremely helpful too.
As there is no "steering knuckle"
There is a few other Knuckle parts listed.
Include a picture of what you need.
If you need to see it on a blueprint go to here:
And being armed with the part number helps too
Also find out what other tractors used the same part, there is more than likely, more than one model.
The last 2 I can help with if you give me more info.
Stevn
Kubota l345
Jan 4, 2023
For some reason there are multiple part numbers none that work it’s the left steering arm knuckle . 37800 43953 is one number they gave me. I do believe it was used on other tractors I think the L305 . It is a 2wd.
motionclone
May 4, 2018
1,399
996
Maine
Had the sme problem with my L345DT its a common problem. I welded mine back together and also bought a NOS one from I believe 007Kubotoguy here. Or maybe it was from ebay. Youre going to have to scour the internet for a junkyard one. They arent made anymore.
Pau7220
Aug 1, 2017
785
279
Scranton, PA
Click on the envelope in the upper right corner and send 007Kubotoguy a private message. He has helped many of our members with parts.
rbargeron
Jul 6, 2015
1,170
235
western ma
Knuckles are 35340-11210 RH and 35340-99011 LH
2wd L345 steering parts drawing from KSC website:
If you poked around an auto junk yard you might find something close. Or maybe a local fab shop could make you one, especially if they have the other one to go by.
