L3400 battery size/upgrade?
Bulldog
M 9000 DTC, L 3000 DT
Mar 30, 2010
5,434
76
Rocky Face, Georgia
Looks like it's a 490CCA battery. From what I've ran into with my Kubotas the battery dementions is what gets you in trouble. My 3000 didn't have any room for anything bigger than stock. I got 11 yrs out of the factory Kubota battery. Might want to consider staying with original equipment.
UWAdventurer
Kubota L3400 w/FEL & Woods 7500 backhoe
May 24, 2011
39
Coatesville, IN
You are correct, it looks like there are metal ears welded into the battery area that will only let a certain length battery be installed. That could be worked around if needed I believe but the battery would have to still fit between the hold down bolts. It looks like it could be wider and taller without a problem. I had a chance to look at mine very quickly since it was raining. I would like more CCA and reserve. I will get the dimensions and will visit the auto parts store to check to see what will fit. I have found out that it is a group 24 battery. Thanks for the help.
Bulldog
Mar 30, 2010
5,434
76
Rocky Face, Georgia
Not sure if it's the right size or not but Auto-zone lists a 24F-DLG that's 750 CCA and 130 min reserve. I had one of their gold series batteries and it did very well but it was in a car not a tractor.
MagKarl
L245DT
Aug 2, 2010
663
Olympia, WA
I find it surprising that a 35hp tractor would have a 490cca battery, that seems pretty small. I have a regular full size pickup battery in mine, 850cca/1000ca, same as I use in my diesel pickup. I guess I'm lucky to have the room.
