L3130 fuel problem
Eikermann
L3130 GST
Feb 15, 2026
15
Sanford,nc
Trying to start a l3130 gst that has been sitting for a year or two. I seem to not be getting any or enough fuel. I tried the fountain test and saw no flow, opened the primer thumb screw and tried that also. Is there anything else I need to possibly check with the injection pump since it has been sitting?
Hugo Habicht
G1900
Jun 24, 2024
1,301
1,867
Ireland
I would start at the tank, through the fuel filters, fuel pump (if there is). Diesel pest, water ingress would be a more likely cause than the injection pump.
10,329
First check fuses for the Stop solenoid (which in this case is a run solenoid).
There are fuses on the left side by the radiator along with fuses under the dash.
That will stop fuel out of the injection pump, but not in.
If your not getting fuel from the lift pump to the injection pump, then the issue is before it.
lift pump, fuel filter, tank all can cause this.
DO NOT remove or mess with the injection pump or any setting or adjustments around it.
It is very rarely the Injection pump causing the issue.
2,702
As NIW states, be sure you have good fuel flow to the injection pump by removing hoses and seeing if there is a full flow of fuel through the hoses. Start at the injection pump and turn the key to the run position if the lift pump is electrical, if it is mechanical then you need to crank the engine to get fuel through the lift pump. If you don’t see fuel flow there then work back towards the fuel tank to find where you do have good fuel flow and remedy whatever is blocking the fuel flow.
