L3010 D1503 engine advice
Hst L3010
Jackson,Michigan
Hello everyone I'm new here. I'm looking for some advice I've got a d1503 that I'm needing to locate a good used crankshaft and rods. And I keep striking out at salvage yards. My crank is beyond being repaired on one rod journal. I'd also be interested in possibly a used engine thanks!
9,186
If you have the Crank being repaired then you can get a rod here:
https://www.kumarbrosusa.com/kubota/connecting-rod-d1503.html
They also have the crank: (it's listed for the D1403, but it's the same for the D1503 and D1703.
https://www.kumarbrosusa.com/kubota/crankshaft-d1403.html
Hst L3010
Jackson,Michigan
I didn't realize the d1403 was the same I'll look into that route thank you. Also the machine shop near me said the journal would have to have a special welding process done on it and he doesn't do it. The journal is already wore down over .60mm and they only have up to a .40mm undersize bearing available. Not sure if you know of any places that could repair it? Thanks
