L3000DT chains
firstpass
L3000DT
Oct 22, 2017
14
Kooskia Idaho
I bought a set of chains for the kubota and tried to install today and found out there is little or no clearance with the heavy set of chains. The tire dealer said he would reverse the wheels to give me the clearance. Is this a common fix. What wheel weights will fit the kubota and how many would one place on each wheel.
I read on one post about chain or not to chain the fronts. I live on a rather hilly drive. any help would be appreciated. I want to be ready for winter this year cause last winter was a record here in Central idaho.
Firstpass
firstpass
L3000DT
Oct 22, 2017
14
Kooskia Idaho
sorry for not being more specific. The local tire shop solved the problem by flipping the inside dish around and in doing so provided the required clearance to run the chains. Thank you for your response.
Stmar
B2650HSDC
May 23, 2017
932
Buffalo, Wyoming
Hate to ask a dumb question but what is the dish you are talking about? Reason I ask is that I am wondering if the dealer did that to my B2650 before it was delivered because I seem to have plenty to clearance for chains.
9,171
R1's and R4's have different style of rims.
R1's have several ways to adjust the width of the tire track.
the centers of the rimes are removable and adjustable.
R4's typically only have one set, offset, and swapping the rims side to side in some cases will change the offset to help with clearance.
