I recently purchased a L2950DT GST and then a 60" 3 point tiller, the tiller works well when I am not moving, but in first gear the tractor and tiller stop. I have read some articles and adjusted the clutch, and still no luck. TS states the tiller is rated for 25-40 HP tractors, mine appears to be 28 with 26 at the PTO according to the service manual. I also tried dumping the clutch while holding the brake on, and the tractor only shuttered a little, not even close to a stall. Is it time for a new clutch, a smaller tiller or both?
Thank you,
Thank you,
