L2900 Won't move
wabntenn
L2900 FEL 4WD
May 19, 2012
Cumberland Gap Tennessee
My L2900 was working fine low speed second gear shuttling forward to reverse just fine went back pushed in the clutch dropped the three point shuttled to forward let out the clutch and NOTHING! No pop bang or crunch the tractor won't ingage. Hauled it home without opening it up the high to low shifts, the 1-4 shifts and the shuttles shifts. Drained the fluid no metallic fine at all.
Any ideas before I procede to do what I don't want to do [split it]?
Stumpy
L175
Dec 1, 2011
848
NE Ohio
I'm not sure how much help we can be. Not many of us have been inside a shuttle transmission. Though the lack of metal and suddenness of it makes it sound like a stuck\plugged valve to me. I'd poke around in the thing's brain and see if anything obvious pops up.
meanjean
Kubota MX4700
Aug 10, 2010
922
Hazelridge, Manitoba
Make sure the high-low shifter is engaged.
I had a similar problem last year.
I accidentally bumped the hi-low knob and it settled in neutral.
