l2850 power steering
hillfarm
l2850
Oct 10, 2019
chatham ny
hi all
first post to the forum. i have searched and used other posts for great info for years
my PS unit started leaking fluid badly. i have a rebuild parts kit ready to go. i have the hyd line and all nuts bolts brackets disconnected.
i cannot get the unit to slide out of the tractor frame rails.
is there a trick i dont know of?
thanks
9,186
Did you remove the bracket on the left hand side?
hillfarm
l2850
Oct 10, 2019
chatham ny
Yes that bracket, all bolts and hoses disconnected.
It's loose in the cavity between frame. It just seems like there is not enough room to get it out. It binds on the frame rails and the spindle binds on axle
9,186
It's very possible you'll have to remove the battery try and the maybe even the radiator to pull it out the top,.
And on some it requires that you drop the frame to get the unit out, very easy just bolted to the sides of the block.
damarshall7
L2850 with 4530B Backhoe
Sep 11, 2019
Clayton, NC
I just finished this a few weeks ago on the same tractor. It was not easy, took several hours of jostling it back and forth to get it out. I would recommend removing the hood, radiator, fan support and battery box, it will make things 10x easier, and those parts are very easy to remove.
If you think it is hard to get out, just wait until you try and put it back in and line up the steering. Its even more difficult. There is also a blind bearing that takes a bit of work to get loose in the pump.
If you have any questions, shoot me a message. Im new to this site, so im not sure if i have to have a certain amount of posts to reply.
alanishep
L2850
Jul 15, 2020
south wales uk
Hello, Im new to this forum and just read the post on the PS pump, where did you get the rebuild kit from and what does the kit contain. Many thanks, Alan.
