Hello, I recently bought the tractor and found the battery acid level light on the dash permanently on (as ignition is on), while the sensor is off. I am not quite sure, if the sensor will fit a standard lead-acid battery ( exchanging one of the filler-plugs), as I contemplate to buy a new one (it is about 50€/$). Alternatively, I am going to try feeding the wire via a 1,2 (or 1.5 V lithium batt) Volt AA battery with the negative pole connected to the 12 V tractor battery. My idea is, that the AA battery simulates the 2 volts , the sensor would normally pick-up from the tractor-battery. Either way, I hope that I match the proper wire, which leads to the transistors, which switch bulb on and off in the dash. Taking off the bulb is my final remedy. I would appriciate any help on this topic. Heinz
