L285 - How critical is Hyd fluid level ?
MrPeabody
L285
Apr 17, 2017
Pleasant Plain
Hi all,
Last year I bought a L285 and I've been sprucing it up as I find time. Recently I drained the gearbox and refilled it with some Universal Transmission/Hydraulic fluid from Walmart.
My manual said the capacity was 7.3 gallons so I bought 7 gallons figuring all the old oil wouldn't drain out anyway so 7 would be fine.
When I refilled with the new 7 gallons nothing came out of the full level hole on the side of the transmission.
Walmart only sells the oil in 5 and 2 gallon containers. I doubt that my tractor is 2 gallons low, so if I buy 2 gallons and only have to put a little bit in to fill it I will be left with a gallon or so of oil that I have no use for.
I could either leave the oil level as it as it is and figure it's good enough, or I could dump 2 gallons in and over fill it a little.
Would over filling the tranny harm anything ?
Thanks !!
2,835
typically best to be slightly UNDER filled than over filled.
Take a piece of "wire" and bend it - so that it can go down into the overflow hole - use it as a mini dipstick - to see where you are relative to the overflow hole.
MrPeabody
L285
Apr 17, 2017
Pleasant Plain
Great idea, thanks so much !!
mickeyd
Mar 21, 2014
1,192
Guin, AL
So Mr. Peabody, are you one like he was??? :D
Chris f
West bend Wisconsin
Questions on this subject so this level does transmission and the 3 pt hydrolics off one lubricant? Next question can I add a remote coupler to operate a single hose ram since it doesn't appear to have down draft mine is also aL285 thanks fellas
2,073
Yes there is only one fluid for hydraulics and gears in the transmission.
Next question I have no idea about that.
kubotafreak
Sep 20, 2018
1,049
395
Arkansas, US
Check with all implements lowered. Levels change considerably with loader or hydraulics in the air. My l60 will go to mid on the dipstick if the loader is mid way up.
