L2800DT Rear Tires
neilstamper
L2800 and attachments
Mar 5, 2011
New Castle, Va
New Orange Tractor Owner in Virginia
I just bought a new Kubota L2800DT. My first Kubota.
It has Ag Tires. It seems that the rear wheel base is narrow, especially since
I use it on hilly land. I noticed that the Kubota rear wheels have different bolt slots for reversing the wheels outward. Is this recommended, and safe?
How much wider will this make wheelbase? Is there any downside to doing this?
I am just trying to get a little wider stance for stability.
Much Appreciated,
Bulldog
M 9000 DTC, L 3000 DT
Mar 30, 2010
5,434
80
Rocky Face, Georgia
It's fine to widen the rear wheels out. Just don't reverse the front. You might even look at adding fluid to your rear tires for some extra weight down low. As far as the width goes. I think your tractor is about the same as my L 3000. Mine is about 60" wide at the rear tires.
HickoryNut
BX25DLB/PForks,Front Blade,3PH,and 3Pt STUFF, BXPanded UA, Piranha, BH Dolly,Rip
Apr 15, 2011
130
NE Georgia
Yep, Bulldog says it right. I'm all wide with the rears reversed and loaded on my B7100 Makes a big difference on the hillsides.
Eddie Jr.
B3200 HSD
Mar 27, 2011
152
Ottawa Valley, Ontario, Canada EH!
My B3200 is aprox 54" wide with the R4 style tires in "regular wheel" set up.
The loaded tires will help for sure. Lots of good reading on here in several threads about liquid ballast for the tires.
M.
